HELP NOOJ
Posted: Sat Mar 12, 2011 8:01 pm
by joecrx
i fitted rsvr 04 i think rotors to the falco but the bolts from the falco wont fit :smt010 , the rotor holes seem to have a reses so im looking for 12 that will fit , and the 4 caliper bolts,
can you give me a price inc delivery , dont have to be anything shiny or bling , as long as they fit :smt001 ,
EDIT the guy says they are from a 04 falco
cheers
Posted: Sun Mar 13, 2011 12:00 am
04 RSVR was the first of the new shape ones and had the radial calipers, so I'm guessing the rotors will have a different offset to the Falco, so may not fit with our calipers?? (last production of the Falco was 03, may have been registered as 04 though). Will look into it.
Posted: Sun Mar 13, 2011 9:25 am
Nooj wrote:04 RSVR was the first of the new shape ones and had the radial calipers, so I'm guessing the rotors will have a different offset to the Falco, so may not fit with our calipers?? (last production of the Falco was 03, may have been registered as 04 though). Will look into it.
No I don't believe the rotors have a different offset, the radial braked 03 Mille R and 04 onwards RSVR has a 5mm thicker front hub so that it all lines up.
Posted: Sun Mar 13, 2011 11:58 am
by joecrx
i put the old one and the new one together hey look the same offset, and the center pattern is the same apart from the new ones wich are gold , and have a reses for the bolt or allan key type bolt ?
Posted: Sun Mar 13, 2011 6:45 pm
by joecrx
feel a bit lazy tonight so copied my reply from AF1 :smt001
good advice there Kzmillie , i will use them to get throught an MOT , and look for ones with 6mm hex later , thats if they fit
heres the rotors i bought might need to scrool to the bottom
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWNX:IT
i was buisy yesterday fitted front rotors used old bolts as i need to get wheels ballanced , back rotors front pads and rear,
took the wheels to get new boots fitted £10 each fitted and balanced bargain i think
also fitted the standard clutch slave today as the MPL was leaking
kinda strapped for cash at the moument so took a chance on these
anyone know much about them , if not i will soon report my findings
another falco nearly ready for the uk roads or whats left of them ( pothole ally )
cheers
Posted: Sun Mar 13, 2011 8:30 pm
by joecrx
UPDATE UPDATE :smt010 :smt010
Got my new tyres fitted , although the balancing was oh within tollorence , i hit a pot hole last year i nearly got flung of the bike when the back wheel went down after the front took a dive and tried to buckerooo me of the bike this is the rezult, i did notice the dent on the rim but did not notice the whole wheel is out of round
heres the pics
so im looking for a front wheel anyone got a spare
Posted: Sun Mar 13, 2011 11:11 pm
Front or rear? I have a spare rear in the garage.
Posted: Sun Mar 13, 2011 11:27 pm
Nooj wrote:Front or rear? I have a spare rear in the garage.
............. a clue .....................
:smt009
Posted: Mon Mar 14, 2011 6:09 pm
by joecrx
:smt003 :smt003 :smt003
Posted: Mon Mar 14, 2011 11:23 pm
by HisNibbs
I do.
Like with most of the standard parts I'm holding it for the hypothetical day where I might need to return it to standard and sell off the special bits. So though its a waste of space in the garage it still has value.
Has discs and reasonable Michelin 2 CT.
You can PM me if you want to explore options.
Posted: Mon Mar 14, 2011 11:41 pm
You mean you actually read the stuff people put on here?
Posted: Mon Mar 14, 2011 11:54 pm
Yep - Sometimes I even read the line above my reply :smt003
Posted: Tue Mar 15, 2011 1:00 am
I just guess. Amazing reply success rate considering!
Posted: Fri Mar 25, 2011 6:49 pm
by Moose
:smt006 joecrx
Did you get sorted :smt017
