Who said Black was faster?
Posted: Mon Jan 12, 2009 11:52 pm
Dark Suckers
Bell Labs Proves Existence of Dark Suckers
For years it has been believed that electric bulbs emitted light. However,
recent information from Bell Labs has proven otherwise. Electric bulbs
don't emit light, they suck dark. Thus they now call these bulbs dark
suckers. The dark sucker theory, according to a Bell Labs spokesperson,
proves the existence of dark, that dark has mass heavier than that of
light, and that dark is faster than light.
The basis of the dark sucker theory is that electric bulbs suck dark. Take
for example, the dark suckers in the room where you are. There is less dark
right next to them than there is elsewhere. The larger the dark sucker, the
greater its capacity to suck dark. Dark suckers in a parking lot have a
much greater capacity than the ones in this room. As with all things, dark
suckers don't last forever. Once they are full of dark, they can no longer
suck. This is proven by the black spot on a full dark sucker. A candle is a
primitive dark sucker. A new candle has a white wick. You will notice that
after the first use, the wick turns black, representing all the dark which
has been sucked into it. If you hold a pencil next to the wick of an
operating candle, the tip will turn black because it got in the path of the
dark flowing into the candle.
Unfortunately, these primitive dark suckers have a very limited range.
There are also portable dark suckers. The bulbs in these can't handle all
of the dark by themselves, and must be aided by a dark storage unit. When
the dark storage unit is full, it must be either emptied or replaced before
the portable dark sucker can operate again.
Dark has mass. When dark goes into a dark sucker, friction from this mass
generates heat. Thus it is not wise to touch an operating dark sucker.
Candles present a special problem, as the dark must travel in the solid
wick instead of through glass. This generates a great amount of heat. Thus
it can be very dangerous to touch an operating candle. Dark is also heavier
than light. If you swim deeper and deeper, you notice it gets slowly darker
and darker. When you reach a depth of approximately fifty feet, you are in
total darkness. This is because the heavier dark sinks to the bottom of the
lake and the lighter light floats to the top. The immense power of dark can
be utilized to mans advantage. We can collect the dark that has settled to
the bottom of lakes and push it through turbines, which generate
electricity and help push it to the ocean where it may be safely stored.
Prior to turbines, it was much more difficult to get dark from the rivers
and lakes to the ocean. The Indians recognized this problem, and tried to
solve it. When on a river in a canoe travelling in the same direction as
the flow of the dark, they paddled slowly, so as not to stop the flow of
dark, but when they traveled against the flow of dark, they paddled quickly
so as to help push the dark along its way.
Finally, we must prove that dark is faster than light. If you were to stand
in an illuminated room in front of a closed, dark closet, then slowly open
the closet door, you would see the light slowly enter the closet, but since
the dark is so fast, you would not be able to see the dark leave the
closet.
In conclusion, Bell Labs stated that dark suckers make all our lives much
easier. So the next time you look at an electric bulb remember that it is
indeed a dark sucker.
Posted: Mon Jan 12, 2009 11:53 pm
by ligloo
have a large drink dear, I'm starting to worry :smt002
and....
closet.
don't they say it? :smt003
Posted: Tue Jan 13, 2009 12:01 am
Heaters should also be called cold suckers. :smt001
Posted: Tue Jan 13, 2009 1:18 pm
I'll just stay on the Dark Side. :smt004
Posted: Wed Jan 14, 2009 6:46 pm
by lazarus
And of course the engine in your bike is sucking the horizon towards you. And since some of the horizon is solid, you need to turn the bars to suck in a slightly different direction when you turn a corner. And if you buy a big bike with a big engine like a Harley, that makes you a big sucker.
Posted: Wed Jan 14, 2009 6:58 pm
:smt005 :smt005 :smt005 :smt005 :smt005
Posted: Wed Jan 14, 2009 7:31 pm
Posted: Thu Jan 15, 2009 9:50 am
by FalcoPhil
So all those with Black bikes are dark suckers !!
Or are they just suckers???
Posted: Thu Jan 15, 2009 12:31 pm
Back to the original question -
Who said black was faster ?
Well there was me for starters, plus -
Falcoholic
etc.
etc.
etc.
etc.
Beware of the Dark Side, you suckers!
Posted: Thu Jan 15, 2009 1:12 pm
by Gio
Since when has dark been black ? :smt017
By this theory white has got to be the lightest dark and seeing as white bikes are so rare, silver must be he next lightest dark, so its the fastest :smt003
Posted: Thu Jan 15, 2009 1:42 pm
As matter gets sucked in to a black hole it becomes incredibly dense and eventually comes to a crashing halt.
This is a uncannily similar to those people that get sucked into the sad belief that the black bikes are fastest.
Posted: Thu Jan 15, 2009 2:00 pm
by Falcoholic
It's not that black is neccesarily fastest is just that all the others are significantly slower.
:smt001
Posted: Thu Jan 15, 2009 2:37 pm
by FalcoPhil
Falcoholic wrote:It's not that black is neccesarily fastest is just that all the others are significantly slower.
:smt001
That's because they're all being pulled backwards by the Dark Suckers (Black Bikes)
Posted: Thu Jan 15, 2009 8:12 pm
by Gio
:smt001
Impossible with the effects of slip streaming.
Posted: Thu Jan 15, 2009 8:42 pm
Pulled back??
So theyre ahead of the black bikes is what youre saying..... :smt002
