Ninja 250R - 2008
Ninja 250R - 2008
#1 Post by Kwackerz » Sun Feb 24, 2008 3:03 pm
Model Year: 2008
Engine type: Liquid-cooled, 4-stroke Parallel Twin
Displacement: 249 cm³
Bore x stroke : 62.0 x 41.2 mm
Compression ratio 11.6:1
Valve/Induction system: DOHC, 8 valves
Maximum power: 24 kW {33 PS} / 11,000 rpm
Maximum torque : 22 N·m {2.24 kgf·m} / 8,200 rpm
Fuel system Fuel injection: ø28 mm x 2 (Keihin)
Dual throttle valves
Ignition Digital
Starting Electric
Lubrication : Forced lubrication, wet sump
Transmission: 6-speed, return
Final Drive: Sealed chain
Primary reduction ratio 3.087 (71/23)
Gear ratios: 1st 2.600 (39/15)
Gear ratios: 2nd 1.789 (34/19)
Gear ratios: 3rd 1.409 (31/22)
Gear ratios: 4th 1.160 (29/25)
Gear ratios: 5th 1.000 (27/27)
Gear ratios: 6th 0.893 (25/28)
Final reduction ratio 3.071 (43/14)
Clutch: Wet multi-disc, manual
Frame type: Tube diamond, steel
Rake/Trail 26° / 82 mm
Suspension, front 37 mm telescopic fork
Suspension, rear Bottom-Link Uni-Trak with gas-charged shock and 5-way adjustable preload
Wheel travel, front 120 mm
Wheel travel, rear 130 mm
Tyre, front 110/70-17 M/C (54S)
Tyre, rear 130/70-17 M/C (62S)
Brakes, front Single 290 mm petal disc. Caliper: Single balanced actuation dual-piston.
Brakes, rear Single 220 mm petal disc. Caliper: Dual-piston.
Steering angle, left / right 35° / 35°
Dimensions (L x W x H) 2,085 mm x 715 mm x 1,115 mm
Wheelbase 1,400 mm
Ground Clearance 135 mm
Seat height 775 mm
Fuel capacity 17 litres
Dry weight 154 kg
A cool looking race rep! And 33PS to entice those new restricted riders in to the racebike scene without having to go for direct access!
From the Kawasaki UK website:
RIDER-FRIENDLY PACKAGE MEETS TOP NINJA STYLING
In the city or on twisty country roads, the lightweight, rider-friendly Ninja 250R is a blast to ride! With an engine character that can be fully exploited, a compact, easyto-operate chassis and full-fairing supersport styling worthy of its moniker, this model was developed to offer street sport performance to riders of all skill levels.
Powered by a gutsy 249 cm³ parallel twin, this lightweight Ninja is loaded with riderfriendly features such as a low seat height, low-effort controls and a comfortable riding position. Best of all, like the Ninja ZX-10R and 6R supersport bikes, the Ninja 250R places control firmly in the hands of the rider, making it the most exciting bike in its category.
Lightweight handling, easy controllability and gutsy throttle response make the 250R fun to ride on city streets. For great handling and high stability it runs 17-inch wheels. Powerful 2-piston disc brake delivers plenty of stopping power with sensitive feel at the lever. Like Kawasaki’s other sport models, the Ninja 250R is fitted with petal discs for efficient heat dissipation. A natural, upright riding position and comfortable ergonomics give riders the feeling of control needed for the active, sporty riding for which the 250R was designed.
One look at the Ninja 250R tells everyone that this bike is the Real Thing. From the aggressive full fairing and kicked up muffler to the racy dual seat, this is the most stylish bike in its category. The fairing and windscreen not only look great, they deliver excellent wind protection for this exciting bike’s wide range of riding situations.
