Oxford Solariser versus winter
Posted: Fri Mar 11, 2016 6:20 pm
by randomsquid
Started the Falco today for the first time since whenever it was I last rode it. Got to be a few months. Put some petrol in and it started after about four revolutions.
Sounded a bit sluggish to be honest but without the charger on it would have been flat as a pancake by now.
Posted: Fri Mar 11, 2016 6:38 pm
I've got one, still needed to put my battery on charge for a few hours for the post winter fire up, the solar charger got disconnected when the bike tent took a hammering in the recent winds.
The battery voltage was 11.3 so the solariser had clearly put some charge in over a 4 month lay up
Re: Oxford Solariser versus winter
Posted: Fri Mar 11, 2016 8:05 pm
randomsquid wrote:Put some petrol in and it started after about four revolutions.
The French
The Industrial
The People's
The Russian
..... Took quite a few years and much bloodshed then?
Posted: Sat Mar 12, 2016 7:14 pm
by randomsquid
Mine was 11.5 on the dash which is marginal for starting but I reckon it's got to be better than leaving the battery to fend for itself.
Posted: Sat Mar 12, 2016 7:15 pm
by randomsquid
D-Rider wrote:randomsquid wrote:Put some petrol in and it started after about four revolutions.
The French
The Industrial
The People's
The Russian
What do you expect from the products of Oxford.
Posted: Sat Mar 12, 2016 8:34 pm
by BikerGran
I have a cheap version that does the job perfectly - I used to have to buy a new battery nearly every year, I won't say how long I've had the current one cos that really would be tempting providence!
Posted: Mon Mar 14, 2016 1:01 pm
by wayno
I used to use a solariser before I moved and got power in the garage, I found that putting 2 in parallel kept the battery perfectly topped up over winter, 1 just didn't quite cut it in the gloom and doom of winter.
Posted: Mon Mar 14, 2016 6:51 pm
by Gio
Best thing is to ride it once every 2 or 3 weeks for an hour.
Posted: Mon Mar 14, 2016 6:54 pm
wayno wrote:I used to use a solariser before I moved and got power in the garage, I found that putting 2 in parallel kept the battery perfectly topped up over winter, 1 just didn't quite cut it in the gloom and doom of winter.
Genius ! So bloody obvious its too easy to overlook
Posted: Mon Mar 14, 2016 9:09 pm
Agree - I use 2 Maplins solar panels (same as Oxford, I'm sure) and they keep a car battery perfectly topped up, even over winter.
But the car is in the South of France...
Posted: Mon Mar 14, 2016 9:44 pm
I use solar panels to charge my battery too .... 20 big ones on my roof that power lots of my electrical things
Posted: Tue Mar 15, 2016 10:45 pm
by randomsquid
Using two in winter sounds like a top tip.
I've been using mine since last spring and through the riding season the voltage on the dash was always the same as when I'd just got back from a run.
After a few months of winter idleness not so much.
