what is a good price
Posted: Fri Dec 19, 2014 6:03 pm
by Tonyunn
The last time I rode the bike my left boot got oil all over it, I knew straight away the oil filler plug had failed again, ptfe tape didn't work.
So I bought an alloy filler plug for £20, it looks great and is nice and tight but is it worth it.
I suppose it comes down to the basic thing of it it works then yes, but it's difficult to look at it and say thats a bargain.
Re: what is a good price
Posted: Fri Dec 19, 2014 6:47 pm
by TwinkietheKid
Tonyunn wrote:The last time I rode the bike my left boot got oil all over it, I knew straight away the oil filler plug had failed again, ptfe tape didn't work.
With the O-ring?
Mine disappeared once after I over looked that little item.
Posted: Fri Dec 19, 2014 8:16 pm
Agree with Twinkie....
If you don't have the 'o'ring fitted then the new shiney plug will work loose, your left boot will get covered again.....
Posted: Fri Dec 19, 2014 9:19 pm
by Tonyunn
It came with new O ring, fits nicely.
Posted: Fri Dec 19, 2014 10:26 pm
by BikerGran
I know I'm stating the bleedin' obvious - but wasn't that a very expensive O ring?
Posted: Sat Dec 20, 2014 8:04 am
by Tonyunn
For the benefit of clarity, I had an O ring I think the problem was the oil plug filler was plastic and the threads were gone, it never really felt tight and I think the oil was passing under pressure through the threads.
I think in the past someone had put the filler in badly and forced it tight cutting a new thread.
Phone picture, hence quality.
Posted: Sat Dec 20, 2014 11:54 pm
by BikerGran
That puts a different light on it.
Posted: Sun Dec 21, 2014 12:13 am
by TwinkietheKid
BikerGran wrote:That puts a different light on it.
Indeed
Posted: Mon Dec 22, 2014 6:11 pm
by randomsquid
Does it keep the oil in and at the same time look posh? If so then I'd say it was worth it. I quite like the plastic ones with 710 on. Must be a common part cause all bikes seem to have the same number.
Posted: Mon Dec 22, 2014 7:40 pm
If your left boot I dry, your mind at rest and you like the look then it's a good price,simple as
Posted: Mon Dec 22, 2014 7:47 pm
by nicketynoo
£20 is loose change mate! I lose that sort of cash running for a bus, isn't there any way of fitting 2
Posted: Wed Dec 24, 2014 12:55 am
by BikerGran
randomsquid wrote:I quite like the plastic ones with 710 on. Must be a common part cause all bikes seem to have the same number.
Do you know, cars have the very same thing!
