a quieter exhaust
lazarus
a quieter exhaust
#1 Post by lazarus » Fri Oct 25, 2013 12:11 pm
dont know why BMW have done it but the exhaust on the twin cam GS is loud. Aftermarket can loud. And a bit harsh too.
I appreciate that this is the reverse of what most people want but how can I modify the silencer to make it quieter. Incidentally, its the factory standard and done just 1400 miles so its lighly unlikely the existing packing is bu**ered.
I dont want to spend lots of money on an aftermarket can if I can make the standard one quieter.
#2 Post by D-Rider » Fri Oct 25, 2013 12:18 pm
Buy a Falco with a standard exhaust - whisper quiet and probably cheaper than a new system for a beemer.
Sorry I don't have an answer for what to do to the BM system itself
#3 Post by randomsquid » Fri Oct 25, 2013 4:17 pm
Generic DB killers are about 20 quid on fleabay if your can has an appropriate hole, I know some modern stuff is weirdly shaped.
I tried just hopefully bodging some extra packing down a can once. Went choke, cough, cough, splut, bang - and shot it all back out again.
lazarus
#4 Post by lazarus » Fri Oct 25, 2013 4:43 pm
its a double hole in an oval end cap. cant find a suitable db killer
#5 Post by randomsquid » Fri Oct 25, 2013 5:01 pm
Just a thought, has it got an exhaust valve in the can somewhere? Might be stuck or have been disabled by a previous owner. Saw one on a recent z1000. Pivotty thing on the back of the can worked by a couple of cables attached to a motorry thing on the bike.
#6 Post by fatboy » Fri Oct 25, 2013 5:31 pm
If it isn't the pivotty thing stuck....
how about having some baffles fabricated, not that much to them, you just need the correct size
lazarus
#7 Post by lazarus » Tue Oct 29, 2013 1:35 pm
randomsquid wrote:Just a thought, has it got an exhaust valve in the can somewhere? Might be stuck or have been disabled by a previous owner. Saw one on a recent z1000. Pivotty thing on the back of the can worked by a couple of cables attached to a motorry thing on the bike.
yes its got a pivoteyu thing in the pipe ahead of the silencer. but I dont thing its stuck. in any case, apparently its designed to close at the revs at which exhaust noise is measured for the eu limits. so its normally open anyway.
