Tyre Shagged
Posted: Tue Apr 10, 2007 4:33 pm
by John1000
What the hell caused this to the rear tyre . Is it poor suspension or pressure or the fact it was a soft compound on a reasonably hot day. The pressure was 29psi the tyre was a Bridgestone bt002 soft. Really need to know what to sort out.
Posted: Tue Apr 10, 2007 4:38 pm
by Gio
Get yer knee down?
How many laps, where at and times please
Posted: Tue Apr 10, 2007 4:44 pm
Respray the bike, assuming it's the one in your avatar.
The tyres obviously can't cope with fast yellow.
Posted: Tue Apr 10, 2007 4:51 pm
Big V Twin, Soft Compound, Hot Day, Racetrack, Not a new tyre (possibly?)
That tyre looks normal for coming off the track at the end of a decent day's circulating?
I'd say if anything it'd be the rider input.
Hard out of the corners were we?
Posted: Tue Apr 10, 2007 4:53 pm
by John1000
Silverstone was the place and as for time haven’t a clue but I would say I was near the top end of the inters pace wise.
And have a bit of a confession I wasn’t on the Falco.
Would like to know if it was heat or a poorly set up bike.
And as fer getting my knee down sometimes I did some times I didn’t.
Posted: Tue Apr 10, 2007 4:56 pm
by John1000
Sorry should have said new tyre and looked like that after fist session.
Posted: Tue Apr 10, 2007 4:58 pm
After the first session!! Jeezus! I reckon that was a soft compound, and then some!!
What bike was it btw.
Fireblade?
Posted: Tue Apr 10, 2007 5:02 pm
Have a look at this site
http://www.feelthetrack.com/tire-wear.html
Gives quite a good explanation of the varying wear types. I'd bank on cold tear maybe? Would go with it being the first session 'n all.
I'd be tempted to nip over to
www.motoforum.net and ask about on there, theyre all club racers and highly knowledable in the art of rubber hoop wear..
Posted: Tue Apr 10, 2007 5:09 pm
by John1000
Twas on me R1
It carried wearing the same throughout the day. The pic doesn’t really show just how knackered it is.
Posted: Tue Apr 10, 2007 5:14 pm
by John1000
Ha that explains it . According to the link I am suffering from heat tear with a little cold tear and maybe a little shock tear.
Posted: Tue Apr 10, 2007 5:20 pm
So your suspension is shot then!
Do you use tyre warmers?
Posted: Tue Apr 10, 2007 5:42 pm
by Fausto
Are you running a little under inflated? That'd make heat build up worse as I understand it.
Posted: Tue Apr 10, 2007 6:07 pm
by Gio
Saw a bloke at Brands a couple of years ago on an R1, mind you they were slicks, but they were fecked after 2 sessions.
Re: Tyre Shagged
Posted: Mon Apr 16, 2007 3:22 pm
by bikesdelsol
John1000 wrote:What the hell caused this to the rear tyre . Is it poor suspension or pressure or the fact it was a soft compound on a reasonably hot day. The pressure was 29psi the tyre was a Bridgestone bt002 soft. Really need to know what to sort out.
Could be a lot of things causing it, what group do you run in?
