Anyone want to buy a Falco? SOLD
Posted: Fri Mar 31, 2017 4:50 pm
by katie1
After a short ownership and another 11k miles, the Falco is going again!
41k miles, slightly tatty and with a lightly bent clip on! No idea how that happened, the previous seller failed to mention it and I didn't notice it myself. Could have been a classic Falco fall over before the stand was replaced?
Have had loads of maintenance work done and just had it serviced again, and new brake pads fitted. Things picked up by the garage are, the oil cooler needs new rubber mounts, they think there is a slight oil leak around the water pump seal and also reckon it needs new front discs (felt fine to me but hey). Tyres will also need replacing in the not too distant future (still plenty of tread but rear is starting to square off)
The good stuff is, Remus cans, Ohlins shock, R&G bungs, handguards, upgraded starter, new battery, rear Givi rack arms, db screen, hugger, datatag, oberon slave cylinder, k&n air filter, braided lines, higher gearing, fireblade side stand, pillion seat and seat cowl. Original exhausts included. Oh, the alarm has been removed too!
Knowing the work that needs to be done, I reckon £1200 (or thereabouts) would be reasonable.
Will put a proper ad together but thought I'd shout out here first. Will probably end up going cheap on ebay but you might just want all the bits and decide it's easier to ride your spares home![/img]
Posted: Fri Mar 31, 2017 7:56 pm
by flatlander
Dare one ask why?
Posted: Sat Apr 01, 2017 11:44 am
by DavShill
That's a shame Katie. Whatever you replace it with, do stick around on here. All bikes and bikers are welcome, we just talk about Falcos a lot.
Posted: Sat Apr 01, 2017 7:44 pm
by BikerGran
Oh yes, If you're getting something else - or even if you're not, PLEASE stick around!
Posted: Sat Apr 01, 2017 8:16 pm
by katie1
Thanks all. Having some serious second thoughts at the mo. More on the other thread...
Posted: Sun Apr 02, 2017 3:44 pm
by bigun
Hi,
Do you have any photos? Tempted to get back into the Falco world.
Posted: Sun Apr 02, 2017 4:20 pm
by katie1
Another returnee! Have you been away long?
Casual photos below (definitely not taken with a sale in mind!).
http://s995.photobucket.com/user/bigfat ... 2000/story
Posted: Sun Apr 02, 2017 4:50 pm
That looks very useable !
Posted: Sun Apr 02, 2017 5:23 pm
by katie1
Indeed it is :)
Ok, it's now on ebay, with an entertaining 99p start...
eBay item number: 182512774610
