Falco parts for sale.
Posted: Fri Jan 01, 2016 3:35 pm
Hi folks I have some panels for sale which some are straight with minimal marks.
But someone has not rubbed them down properly before painting over the top.
I am open offers, but to have bodywork that is not cracked or broken is worth having.
So I have a belly pan which is a skidmarx item. But as I say needs rubbing down and painting...But not cracked.
Rear sub frame...
Screen. Corner is missing, But anyone with a falcuono could easily shape this. The rest of the screen is tidy.
Side panels
Finally a clear lens with LED back plate.
But I would like £100 plus a fiver delivery for this.
The headlight lugs have broken, but still with the light unit, so can be glued back on.
Thanks
Posted: Fri Jan 01, 2016 4:53 pm
by squadron Nero
How much for the rear light lenses jay
Posted: Fri Jan 01, 2016 6:57 pm
squadron Nero wrote:How much for the rear light lenses jay
Messaged on fb karl.
Posted: Fri Jan 01, 2016 8:38 pm
by Dalemac
How much for the side fairings Jay?
Posted: Fri Jan 01, 2016 8:40 pm
Dalemac wrote:How much for the side fairings Jay?
£10 each mate please
Posted: Fri Jan 01, 2016 11:26 pm
Hi Jay, how much for the Skidmarx belly pan?
Posted: Fri Jan 01, 2016 11:34 pm
by Dalemac
blinkey501 wrote:Dalemac wrote:How much for the side fairings Jay?
Awesome, I'll have them, then I can finally get my mille bellypan sorted.
PM me your PayPal info and I'll get it sorted.
Oh, might be interested in the tank too, depending on the price.
Posted: Sat Jan 02, 2016 10:24 am
mangocrazy wrote:Hi Jay, how much for the Skidmarx belly pan?
They normally do 80 quid second hand graham?
But due to needing rubbing down, I would do it for sixty.
There is no mounting kit.
Skidmarx pans are now 130 quid new + fitting kit
Posted: Sat Jan 02, 2016 10:27 am
Dalemac wrote:blinkey501 wrote:Dalemac wrote:How much for the side fairings Jay?
Tank you can have 50 quid mate? I think this is about right for an undamaged tank.
The tank will need rubbing down? But if you have a painting project in mind this wouldn't be an issue.
The tank came to me with no pump.
I don't do paypal though, so we will need to meet up.
Posted: Sat Jan 02, 2016 1:15 pm
blinkey501 wrote:mangocrazy wrote:Hi Jay, how much for the Skidmarx belly pan?
OK, cheers Jay - deal. I take it the fitting kit for the rear is just a couple of angle brackets? How does it fit at the front?
Posted: Sat Jan 02, 2016 1:38 pm
by Dalemac
blinkey501 wrote:Dalemac wrote:blinkey501 wrote:Dalemac wrote:How much for the side fairings Jay?
OK, I'll take the tank as well.
No problem, are you venturing into Lincoln at any point in the near future?
Posted: Sat Jan 02, 2016 1:58 pm
Dalemac wrote:blinkey501 wrote:Dalemac wrote:blinkey501 wrote:Dalemac wrote:How much for the side fairings Jay?
Not sure mate.
Pm me your phone number
Posted: Sat Jan 02, 2016 2:00 pm
mangocrazy wrote:blinkey501 wrote:mangocrazy wrote:Hi Jay, how much for the Skidmarx belly pan?
The front bolts up to the locating points which you will unscrew when removing the aprilia unit?
You can buy the fitting kit direct from skidmarx if required.
Posted: Sat Jan 02, 2016 5:42 pm
blinkey501 wrote:The front bolts up to the locating points which you will unscrew when removing the aprilia unit?
Ah yes, of course - silly me. I knew that... :)
blinkey501 wrote:You can buy the fitting kit direct from skidmarx if required.
Yes. That did also occur to me shortly after I posted... Put it down to the delayed effects of NYE...
Posted: Sat Jan 02, 2016 7:01 pm
mangocrazy wrote:blinkey501 wrote:The front bolts up to the locating points which you will unscrew when removing the aprilia unit?
