A mate of mine is selling this one e-bay including the extended brake lines you need, I said I'd place a link on here for him
http://www.ebay.co.uk/itm/220961726201? ... 500wt_1202
RSVR special top yoke and raised bars for sale on ebay
Clarification:
All Ohlins forks fitted to the Aprilias have the same diameters - though top and bottom yokes are different sizes as the diameter of the Ohlins forks changes along their length.
The only difference between MilleR based bikes and RSVR Factory based bikes is that the offset is about 1.5mm different - therefore you need to fit top and bottom yokes from the same generation bikes.
The Showa & Marzocchi forks do not use the same yokes as the Ohlins forks as they are a different diameter.
